Dear kudryavcevrm
Plant also then Revit are not "made" by ADSK and so not codet for Vault ......
have you ever tryed to make an apple pie whit out real apple ? it will work but ......
so there are a hole buntch of "bugs" in Plant his selfe and more problems as ADSK thought
cu cw
The option of Ortho pipework/Equipment to have a wipeout or hatch background so they may be layen over existing 2D plans/elevations/sections/images without having to incorperate this background information into P3D.
1) Piping for pneumatic conveying.
2) Pipe for spouting & aspiration ducting.
3) Here is a simple one that had plagued me for YEARS...Why is it that when you do a distance inquiry that there is not a setting so the results are displayed in both architechural AND engineering units? I find myself swiching back and forth constantly.
4) Better manage cashed data to help avoid crashes.
Really Autodesk? Did you really had to change the layout of the forum?
Did somebody asked you to do this or someone new from your management staff wanted to kiss **** and do something interresting in front of the bossess? If it ain't broken don't fix it!!!
Already I'm pissed off at Yahoo for changing again the mail look. It's awfull!! Painfull!
Btw, I've found out that by using Maxthon broser v3 (not the latest updated version) and change the browsing engine (it has a little lightingbolt button on the adress bar) I have the older, tabbed version of fyahoo mail.
If it ain't broken don't fix it!!! We should all have this motto for the things that we ALL like as they are.
One of the wishes is that you can show the isolationthickness and the changing of isolationthickness at the Isometric.
1. Inbuit specs of ASME BPE standards (Tubes, fittings, triclovers, special valves such as flush bottom valves, zerostatic valves) used in pharmaceutical industries
2. End connections including triclover connections apart from butt weld, flanged, SW etc.
3. Possibility to import Revit models directly into Plant 3D.
I understand that the two programs are on separate databases, but some easy buttons for coordination would be great. Such as: P&ID to have the specs listed in the spec folder of P3D, shared values for the Vessel types, etc.
not to sure if this has been asked for before, the ablity to show the model in different states as per how the structural items work, simple, centre line, basic model and a detailed level, the last two would be my prefered then you can have a detailed final model which shows valves etc in good detail, but while drafting you run the simple display to allow for preformance.
2015 P3D Beta Projekt
https://beta.autodesk.com/callout/?callid=45D89BC8F9E04D5E98B558303A72ABAC
cu cw
N)In iso creation, the hypotenuse should be oblique. The extension lines should be parallel to main axes.
O)Possibility to specify a weld number for weld dots that their class is “slip-on”.
P)A method for finding a special spool. For example in most cases in revised iso some spools are deleted and we need to replace them with none constructed spools. The properties for search should be selected by user like size, orientation, length of pipes and ….
Q)Showing weld number (it is better to use joint number) spool number like water marks and a button for show/hide this. Using symbol specified for show in isometric or selecting by user.in this situation it doesn’t need to change to 3dwireframe mode to select weld dots.
R)Show color spec change like spec change in iso.(Let user select it )
S)Showing notes(details) for vent, drain, suction, mitered joint and … in iso.(as per user's setting,the joints of details must be shown and ...)
T)Possibility to manage(save in software) old revisions. And in new iso it should show revised part
using rev clouds and triangle update indexes automatically.
U)In iso creation, possibility to specify which part be first sheet and so on (based on break points prepared by user). P3D often changes sheets in iso creation.
V)Adding R.F.PAD to default catalog and spec. also show weld dots (it is better to use joint dot) for this.(the number of joints should be selected by user,one or two{sometimes a joint number for inside and other one for outside of pad})
W)Sometimes continuation part shown in iso isn’t correct, it must be repaired !!!!!!
Y)Dimension from continuation part should be conformed dimension part in project setup.
Z)Show key plan in orthographic.
AA)Faster iso creation, now it is not comparable to PDMS.
AB)“Weld Annotations” & “Weld Number” should be changed to “Joint Annotations” & “Joint Number”. P3D doesn’t number threaded joints. Let user to select which type be selected. And there is no field for numbering joint for threaded joint in model.
AC)Show joint number are in connected line number (not in next sheet of iso) as existing item (management goals).
AD)Hoses must be added to default catalog
AE) P3D should realize typical part(main collector and a lot of risers) in iso generation and mark them as "Typ." And don't show them in iso.
