AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
View distorted
3 REPLIES 3
soumen.r
695 Views, 3 Replies
View distorted
I drew some pipes in plant 3d 13. I drew some hangers around the pipes. In model space all are vertical where as in paper space some of the hangers are inclined. Am I doing any wrong? Anyone faced this type problem?
Regards
SRoy
Tags (1)
3 REPLIES 3
Can you send us a copy of the model for us to investigate further. Do let me know, if you want me to send you a secure ftp for upload.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Hi Vinod,
Thank you for your comment. I can not share you the 3D model for some security reason. Instead I am sending you some screen shots of that model from Plant 3D for your reference.
Please refer the file names of the images for the actual view, not the view-cube caption; as some times we are finding that view-cube showing us a wrong view in parallel as well as perspective mode.
Please find the attached zip file for your reference.
Soumen
SRoy
Tags (1)
Thanks for the update. Can you check whether you have a certified graphic driver installed. You can download from the link below,
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Also, please update all the service packs from the link below,
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=14116968
If the issue still persists, do let me know your convenient time and contact number for a quick phone call.
”Boost
