AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Vault Basic 2014
11 REPLIES 11
Message 1 of 12
C.Suclupe
866 Views, 11 Replies
Vault Basic 2014
I would like to help me, every time I want to create a Plant 3D project with the Vault option I get the following warning ... attached image .... I hope I can support .... thanks
Tags (1)
11 REPLIES 11
Message 2 of 12
DarrenP
in reply to: C.Suclupe
this doesn't work with vault basic only with vault workgroup and higher
DarrenP
Message 3 of 12
scottmoyse
in reply to: DarrenP
The Vault help file says Vault Basic supports Plant 3D.... I was surprised to read this, since I thought it only worked with paid versions of Vault:
http://help.autodesk.com/view/VAULT/2015/ENU/?guid=GUID-334CC890-1F12-429C-9D6A-B964327CA590
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 4 of 12
cadwomen
in reply to: scottmoyse
dont belive this
vault are a killer ( so in the 2012 it coud not handel Plant more then one reson to let it be )
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Message 5 of 12
scottmoyse
in reply to: cadwomen
@cadwomen wrote:
dont belive this
Sorry? Can you elaborate please?
Scott Moyse
Message 6 of 12
DarrenP
with plant 3d you don't need to have the vault client installed to get the vault add in it comes with plant out of the box
DarrenP
Message 7 of 12
scottmoyse
Yeah. But this is about server edition compatibility. Not addins.
Regards
Scott Moyse
Scott Moyse
Message 8 of 12
cadwomen
for 2012 Plant
use vault as it nessesery in a group , one member do a "check out"   ( so a copy are on his laptop )
make a ckeck in  so far everything fine
but 😉 the copy still on the laptop , he forget to dell manuel !! ( what a **** )
work on on the "copy" and vault check it in later ----- als the things ar gone , no one knows or ifen se what are going on
that was just one of the Big Bug´s
Plant self are not made for ( see Contens file on lokel maschine )
Catalog you have to copy .. and on and on
like i said 2012 ( dont think its better now because Plant still Plant )
cw
Message 9 of 12
DarrenP
this is how i learned about it from here
http://youtu.be/9_LAI0QNDWM
this is still the same for 2014 and 2015
according to the video vault workgroup or higher is required
DarrenP
Message 10 of 12
scottmoyse
Cheers for the video. That's as I understood it originally, pretty sure that help file is incorrect.
Regards
Scott Moyse
Scott Moyse
Message 11 of 12
DarrenP
it wouldn't be the first time
DarrenP
Message 12 of 12
scottmoyse
Vault Basic is supported for non Project workflows.... not sure there are any useful non project workflows. Thanks to Jarrod for clarifying.
Scott Moyse
”Boost
