Hello again 🙂 ,
I have the following questions regarding the valve supports:
I get the pipe support only but the valve support tag I add manually, using AutoCAD. I don't want to have the support tag integrated in the valve tag deffinition because, of course, not all valves have a support.
The creation of a tag with two lines which can adjust its size according to number of attributes filled in (not to have an empty space in the rectangle) will be also acceptable.
From the attachment you can see what I would like to get automatically from Isometrics, if possible.
I’m using Plant3D 2011 at the moment.
Thank you
Hello Roxana-Elena!
Very good post. I have this issue too. No solved so far unfortunately. What we need is similar to a secondary pipe support.
I have put the question in the 2013 whishlist. Hope there will be an answer soon.
Best Regards!
