I have the follow question:
Why in Plant3D is posible to map equipment properties from P&ID to Plant3D objects, and after mapping is imposible to insert equipment in 3D from P&ID with this copied properties? That is one thing that development team forget to add to the program or I do any wrong?
I was created one repor list in the data manager where I add the equipment list od P&ID and one column of 3D dwg name of the same equipment. After created the equipment in 3D and change the TAG to the same as in the P&ID layout, the program detected that it's the same equipment, because in the report list the column "DWG name of 3D" has information. But the mapping properties don't copy (for example manufacture, suply, material, and others...)
