All,
I have never really used Plant 3D, but am helping a client with an unusual issue. He has created a series of custom fittings and appears to have created all of them correctly, meaning in the proper imperial units. However, when he inserts the component, it is significantly smaller than the pipe that he is trying interface with. Please see the attached screenshot to see what I mean. Is there some kind of setting that was missed or something? Anyway, I would appreciate any guidance that can be offered. If you have any questions, please do not hesitate to contact me. Thanks in advance for any assistance and have a most blessed day!
Peace,
Pete
By custom parts do you mean made in a drawing with the "Add Custom Part" or added to a catalog and then added to a spec using the spec editor?
It might have to do with the units that the project was created with. Check it in the drawing with some dimensions. That might give you an idea of of what is going on if the fields use to create it are correct.
Hope this helps.
