AutoCAD Plant 3D General
tmccar
Message 1 of 4 (287 Views)
Useful information in elbow specs
287 Views, 3 Replies
10-02-2012 11:35 AM
I would like to customize the dynamic tool palette that shows my pipe specs. At the moment, the description for an elbow joint is like this: "ELBOW 45, BV, 150,0". This is meaningless to a piping designer, who needs to know the inch size. How can I change what is displayed?
*Expert Elite*
dave.wolfe
Message 2 of 4 (276 Views)
Re: Useful information in elbow specs
10-02-2012 01:50 PM in reply to: tmccar
Use the Spec Viewer Palette.  I find it to be much easier to work with.  You can double-click the item in the top section to insert it, or  you can scroll down and double click the particular size of the item to insert in the lower section (I find this useful for reducing items).
In any case, items generally take the size of the line they are placed in, unless that size is not available in the spec.
Also, the tool palette descriptions are a combination of the short description plus some other properties, which make them not very flexible.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
tmccar
Message 3 of 4 (247 Views)
10-03-2012 06:54 AM in reply to: dave.wolfe
Thanks but I was hoping to be able to customize the fields (and perhaps add a new field).
*Expert Elite*
dave.wolfe
Message 4 of 4 (245 Views)
10-03-2012 07:00 AM in reply to: tmccar
Yea, I get it...a lot of our clients want to do that.  There just isn't a good way to do that, and IMO, the spec viewer is the better way to work.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
You are not logged in.
Announcements
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
