AutoCAD Plant 3D Forum
Useful information in elbow specs
3 REPLIES 3
tmccar
475 Views, 3 Replies
I would like to customize the dynamic tool palette that shows my pipe specs. At the moment, the description for an elbow joint is like this: "ELBOW 45, BV, 150,0". This is meaningless to a piping designer, who needs to know the inch size. How can I change what is displayed?
3 REPLIES 3
dave.wolfe
in reply to: tmccar
Use the Spec Viewer Palette.  I find it to be much easier to work with.  You can double-click the item in the top section to insert it, or  you can scroll down and double click the particular size of the item to insert in the lower section (I find this useful for reducing items).
In any case, items generally take the size of the line they are placed in, unless that size is not available in the spec.
Also, the tool palette descriptions are a combination of the short description plus some other properties, which make them not very flexible.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
tmccar
in reply to: dave.wolfe
Thanks but I was hoping to be able to customize the fields (and perhaps add a new field).
dave.wolfe
in reply to: tmccar
Yea, I get it...a lot of our clients want to do that.  There just isn't a good way to do that, and IMO, the spec viewer is the better way to work.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
”Boost
