Hi all,
I'm trying to create an ADMS to work with Plant 3d and i'm facing a little issue. It's impossible to create new project on the ADMS. Each time i try to connect i get a message saying : "Your test connection to the specified server has failed, Please try again". If I change the sa login credentials to enter the login "sa" and the password AutodeskVault@26200 i've got a different message saying "... error: 26 - Error Locatign server" (the original message is in attachement.
The weird part is when i try the same thing on the ADMS of my localhost machine it works.
For info : Plant 3d 2014 ENU x64 plus Vault Professionnal Client 2013 and Vault Professionnal Client 2014 installed on my machine. OS Win 7 French
Server : Virtual machine Windows 2008 r2 std sp1 ENU with SQL express 2008 sp3 ENU with adms 2014 ENU. Only the collation is in french. I've not installed a new instance for Plant, just the AutodeskVault. Firewall disconnected.
I can connect perfectly to that server with the client Vault and with inventor.
Any idea?
Thank's for help.
i agree with the above
i created an instance called Plant3D
DarrenP
Hi all,
thank's for the tip but it seems that it wasn't necessary anymore to do another instance.
Anyway, i created a new sql instance called AUTODESKPLANT as you can see in the image but the problem still remain.
I'm not a specialist in SQL, is there a way to find what's blocking? A tool to diagnose? Some kind of link tracker.
you can use sql server management studio which is free
which you can get from microsoft
depending on the version of sql it may already be installed
DarrenP
if your using sql express
http://www.microsoft.com/en-us/download/details.aspx?id=7593
the paid versions of sql i believe come with this already
DarrenP
