When I press the + sign on a pipe to add afitting, the fittings gives me automatically a cut piece of 25mm on insertion.
The 25mm piece comes no matter if I place a flange, reducer or tee, and I really do not want ir need it.
Any way I can turn off this setting?
See attachment
The 25 mm is the minimum pipe length as set in the project setup.
But you can enforce a fittin to fitting connection. After you selected the symbol enter F on the command line or select Fitting-to-fitting from the right-mouse menu.
