AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
UK Metric Stainless Catalogue / Specs
2 REPLIES 2
darren.goodman
371 Views, 2 Replies
Morning
I am using Plant 3D 2012, and have been utilising out of the box Catalogues and Specs.
I am asking for help or to be pointed in the right direction, I am desperate for UK Metric Stainless Steel Fittings and wonder if anyone on this forum would like to share their knowledge / or catalogues created.
I find it hard to beleive this package is being sold to the UK market and at best the only true UK fittings available I can see are UK Ductile Iron ?
Whilst I have modified a few fittings and added fittings to specs, my understandning is limited.
Any help would be so much appreciated.
Kindest Regards
Darren Goodman
2 REPLIES 2
Dan.Scales
in reply to: darren.goodman
The content packs that are currently available can be downloaded here (as I'm sure you have seen):
http://autocad.autodesk.com/?nd=plant_content_packs
And you can request new content using this form:
http://autocad.autodesk.com/?nd=form__105
It may be that others have created the content and be willing to share it with you. If not, I would really recommend that you submit a request.
Dan
Dan Scales
Dan.Scales
in reply to: Dan.Scales
To add to my last post, you could also create the catalog you require using the Catalog Builder.
The following video demos this:
http://autocad.autodesk.com/?nd=autocad_tips_tutorials_detail&adsk_tip_id=1702
Dan
Dan Scales
”Boost
