Morning
I am using Plant 3D 2012, and have been utilising out of the box Catalogues and Specs.
I am asking for help or to be pointed in the right direction, I am desperate for UK Metric Stainless Steel Fittings and wonder if anyone on this forum would like to share their knowledge / or catalogues created.
I find it hard to beleive this package is being sold to the UK market and at best the only true UK fittings available I can see are UK Ductile Iron ?
Whilst I have modified a few fittings and added fittings to specs, my understandning is limited.
Any help would be so much appreciated.
Kindest Regards
Darren Goodman
The content packs that are currently available can be downloaded here (as I'm sure you have seen):
http://autocad.autodesk.com/?nd=plant_content_packs
And you can request new content using this form:
http://autocad.autodesk.com/?nd=form__105
It may be that others have created the content and be willing to share it with you. If not, I would really recommend that you submit a request.
Dan
To add to my last post, you could also create the catalog you require using the Catalog Builder.
The following video demos this:
http://autocad.autodesk.com/?nd=autocad_tips_tutorials_detail&adsk_tip_id=1702
Dan
