AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Trying to access "properties" palette, ACAD Plant says its "unknown command"
1 REPLY 1
390 Views, 1 Reply
When I try to use the "properties" palette, ACAD Plant says its "unknown command".  It also says this for the qui kcalculator, design center, quick properties.  I go and modify my cui/workspace setup and save it after I know it looks correct.  Then the next time I restart ACAD Plant, the same palettes are off, and I have to do the same thing all over again.
Does anyone know what the problem may be?
1 REPLY 1
have your tried doing a repair on plant3d from control panel/programs
”Boost
