AutoCAD Plant 3D Forum
Trying to access "properties" palette, ACAD Plant says its "unknown command"
1 REPLY 1
dmitzel2003
387 Views, 1 Reply
When I try to use the "properties" palette, ACAD Plant says its "unknown command".  It also says this for the qui kcalculator, design center, quick properties.  I go and modify my cui/workspace setup and save it after I know it looks correct.  Then the next time I restart ACAD Plant, the same palettes are off, and I have to do the same thing all over again.
Does anyone know what the problem may be?
1 REPLY 1
Rich.O.3d
in reply to: dmitzel2003
have your tried doing a repair on plant3d from control panel/programs
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
”Boost
