AutoCAD Plant 3D Forum
Tri-clamp fitting and pump connections
3 REPLIES 3
diacreek
1959 Views, 3 Replies
any body knows how to find pump with tri-clamp connections and tri-clamp fittings.
3 REPLIES 3
Attila.Vallyon
in reply to: diacreek
Check here:
http://autocad.autodesk.com/?nd=plant_content_packs
Look for Pharma.
It consists ASME BPE pipes and fittings.
Attila Vallyon
diacreek
in reply to: Attila.Vallyon
when I do the migration, the Tri-clamp catalogue is missing.
so nothing came out in the model.
Is the Tri-clamp fitting catalogue integral in the software database or has to be downloaded from somewhere?
By the way, how to migrate the old specs to the current 2014 plant 3D with the catalogue affiliated?
I fails all the time.
Diacreek Engineering Inc.
hello , Please I try to find tri clamp fittings from 3/4" to 4" size2D or 3D
Thank you
”Boost
