Solved by kandarp. Go to Solution.
If you draw a 3DPolyline, you can convert the 3DPolyline to pipe, and it'll cut the elbows to suit also.
Hi there,
Thanks for quick reply from all.
Actually I was modelling 1"NB Line where socket weld bends where used. Hence cut back elbow was not useful to me. However after few try, I come to know about toggle bend option which generated pipe bend for non standard angles while converting 3D Poly line to pipe using "Pipe to Line" command.
Finally I have model with line inclined in 3D. I have attached file which shows inclind line on top of tank at angle in two plan.
Thanks a lot for prompt reply again.
Regards
KANDARP
