AutoCAD Plant 3D Forum
Title block mapping - ISO drawing template setup
4 REPLIES 4
cyklosarin
2510 Views, 4 Replies
I have problem regarding creating ISO drawing template. PLANT 3D doesn't auto-fill attributes in drawing table. Please find attached screenshots with my course of action. The only think software is filling is date, sheet number and overal number of sheets but other fields remain empty (such piping spec, client (custom project properties)). Our regional support told us that this in an issue of AutoCAD PLANT 3D which occurs at random work station. Does anyone have the similar problem? Thanks in advance.
Regards
Dominik
4 REPLIES 4
Attila.Vallyon
in reply to: cyklosarin
Hi!
I have the same problem:
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/ISO-title-block-problem-P3D-2012-SP1/m-p/3385153/high...
Does not seem to have a solution so far, unfortunately!
Attila Vallyon
JarrodMudford
Dominik,
See the solution on this page, http://forums.autodesk.com/t5/AutoCAD-Plant-3D/ISO-title-block-problem-P3D-2012-SP1/td-p/3385153
All custom properties should be fields. This should fix your issue. Also good to check that your other attributes are still mapped correctly.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Jarrod Mudford
Plant Solutions Consultant
Global Services
Autodesk, Inc.
jtegtmeyer
in reply to: JarrodMudford
Jarrod, I agree about the custom properties but the spec doesn't show on the isometric title blocks when you setup the attribute and link it to the database.
thaipham
in reply to: jtegtmeyer
tried to do not put space between word, see attachment. it is work for me
”Boost
