AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Tips and Tricks for the AutoCAD P&ID Administrator
12 REPLIES 12
Message 1 of 13
EileenForan
4486 Views, 12 Replies
Check out the new "Tips and Trick for the AutoCAD P&ID Administrator" whitepaper on Plant Exchange. https://autocad.autodesk.com/ama/orig/plant/Tips_and_Tricks_for_PID_Administration.pdf
In this white paper, you learn to:
- Create and organize template projects
- Create and administer P&ID symbols
- Create and administer Tags and Annotations
- Add user friendly custom Palettes
- Create and use custom reports using Report Creator
View a list of all white papers here: https://autocad.autodesk.com/?nd=whitepapers
Eileen Foran
Community Program Manager
Autodesk Plant Solutions
Autodesk, Inc.
12 REPLIES 12
Message 2 of 13
TRdesigner82
in reply to: EileenForan
Where's the Tips and Tricks for the AutoCAD P3D Administrator?
Message 3 of 13
Links don´t work
Message 4 of 13
KWBJr
The hyperlink did not work... is this being addressed?
Message 5 of 13
PeterQuinn
in reply to: KWBJr
Thanks for the heads up. I'll find out where it was moved to.
Peter Quinn
Senior Product Manager
Autodesk, Inc.
Message 6 of 13
emaiolino
You can not access the link.
They could update?
Thank you very much!
regards
Esteban Maiolino
Titular EMBA Proyectos
Sitio web o nombre del blog
Facebook | Twitter | LinkedIn
Message 7 of 13
PeterQuinn
in reply to: emaiolino
New link is here:
http://knowledge.autodesk.com/support/autocad-pid/troubleshooting/caas/sfdcarticles/sfdcarticles/Tip...
Peter Quinn
Autodesk, Inc.
Message 8 of 13
vakhtang
in reply to: PeterQuinn
Thanks, but now zip file wouldn't open.
Message 9 of 13
KWBJr
I was not able to download the P&ID White Paper... any advise on getting it?
Message 10 of 13
vakhtang
in reply to: KWBJr
error message for zip file....looks like we would never get tho
se tips and tricks... It's tricky!!!
Spoiler
Spoiler
Smiley Sad
Message 11 of 13
KWBJr
in reply to: KWBJr
I would like to get a copy whenever Autodesk works out the transfer issue... Cheers!
Keith Bates
Design / Drafting
Questar Gas
Office * 801.324.3386
Mobile * 801.230.7293
Keith.Bates@Questar.com
[Description: QLOGO-gray]
Message 12 of 13
PeterQuinn
in reply to: KWBJr
It's a PDF, not a zip file. Some versions of IE will fail because of this. Chrome works.
Peter Quinn
Autodesk, Inc.
Message 13 of 13
KWBJr
in reply to: KWBJr
Yes! I changed the extension from ZIP to PDF and it opened in Adobe.
Thank you!
Keith Bates
Design / Drafting
Questar Gas
”Boost
