I am working on a spec and am getting the msg box saying: The components you are trying to connect have different properties (PartFamilyLongDesc). I am placing a valve into the pipe line....of course their PartFamilyLongDesc is going to be different. Anyone seen this before and can give me some insight in resolving? I have attached a pic of the msgbox.
Solved by dennis. Go to Solution.
Are you allowed to place the part on the pipe? If you are allowed, is the part shown as connected or disconnected?
Quentin Contreras
Technical Support Specialist
I can place the valve, after receiving the msgbox for both end connections, each saying that if I do connect, then I will have a "warning glyph". Upon completion, I have no "disconnect drips" and by the way, no warning glyph either.
