AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Text Frame around mtext When Background Mask Enabled
1 REPLY 1
kschu1
668 Views, 1 Reply
I've experienced unwanted text frames around mtext working in Plant 3D drawings when I enable the background mask; unfortunately selecting "F" "OFF" using the wipeout command  doesn't make it disappear.
Any suggestions.
I'm using Plant 3D 2014.
1 REPLY 1
kschu1
in reply to: kschu1
I found the solution to this problem.  My visual style was set to "conceptual"  I changed it to "2D Wireframe" and the text box disappeared.
”Boost
