AutoCAD Plant 3D General
Message 1 of 6 (424 Views)
Supress Dimnensions
424 Views, 5 Replies
01-16-2012 11:51 AM
is there a way to supress vent/drain dimensions on the isometrics like in isogen.
Product Support
jason.drew
Message 2 of 6 (399 Views)
Re: Supress Dimnensions
02-01-2012 01:40 PM in reply to: thebearjed
This is possible. By default the vent/drain piping has all dimensions turned off in project setup:
Plant 3D 2012 defines vent and drain pipe by a certain set of criteria:
- Small bore pipe (according to the value set in Theme Criteria of the Title Block and Display section of Isometric DWG Settings)
- Valve is placed somewhere on the line
- No more than 6 components (for example)
- Begins with an olet
Jason Drew
Premium Support Specialist
Product Support
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Valued Mentor
ybogdanov
Message 3 of 6 (380 Views)
02-02-2012 07:32 AM in reply to: jason.drew
Is posible to change this criteria? Where you find it?
 I was thinking that drain and vent pipes configured in the 3d model, properties of the pipe, type pipe (the same as "New" or "Demolition"), no?
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Product Support
jason.drew
Message 4 of 6 (348 Views)
02-07-2012 03:08 PM in reply to: ybogdanov
As far as I know it's just inside the code where it determines what parts are on the pipe run. If I find out there is a setting for this I will give you an update.
Thank you,
Jason Drew
Product Support
Valued Contributor
Message 5 of 6 (100 Views)
01-02-2014 08:03 AM in reply to: thebearjed
Has there been any updates to the criteria to the vents and drains.  Can we configure it our selfs?  Sometimes my vents and drains are not started with an olet and sometimes they are more than 6 parts (i.e. double block and bleed) and sometimes the drain is up to 2".
Message 6 of 6 (96 Views)
01-02-2014 08:08 AM in reply to: eadkins73
eadkins73...That is exactly them same issues i have. i wish there were some way to specify drain/vent start points.
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
