AutoCAD Plant 3D Forum
Suppress continuing components
3 REPLIES 3
milan_blom
477 Views, 3 Replies
We use Autopie as a stress package. We use the PCF from Plant3D to import into Autopipe
It seems when importing a PCF, also the continuing components on the connecting line (dashed on the iso) are converted.
The is annoying when importing several PCF's of one model.
Is there a way to suppress continuing components on the isometric? In that case I can make a custom iso style for Autopipe export.
3 REPLIES 3
winner117
in reply to: milan_blom
Our company is considering to purchase a stress analys system.
Since we are using plant3D right now.Can you share some pro and con of the Autopipe?
Thank you first for your time.
milan_blom
in reply to: winner117
We used to have Caesar II and switched to Autopipe for the following reasons:
- Easier modelling
- Easier operation (in Caesar the input and output are handled by different modules, so you have to switch back and forth a lot when trying out different designs)
- Easier setup of dynamic analysis
- Cheaper in licensefees and maintenance
Concerning import from Plant3D, both can use the PCF's and both reuquire you to check the model afterwards on materials, schedules, support types, pressure and temperatur and such. Autopipe at the moment has some issues with olet connections (it converts them disconnected, so you have to manually reconnect them), but I'm confident this will be resolved in the future (it has been brought unde rthe attention of development). Caesar II import is also not wihtout issues all the time.
By the way, the mentioned problem with importing continuing components has been resolved in the latest version, as well as the ability to import more than one PCF at the same time and have them combined.
KenFauver
Try this:
Go to your Iso Style folder and open IsoConfig.xml in notepad. Look for the following line:
<IsoContinuationComponents MaxCount="3" IncludeFlanges="false" />
Change MaxCount to have a value of 0 (zero).
Save file and exit.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
”Boost
