Hi I am in a hot spot i require assistance in editing a off page conector
i have a off page conector that i have to type in a chemical name h2so4 with the 2 and the 4 in subscript
how do i do this
PLEASE HELP!!!
Solved by WIEHAN. Go to Solution.
There would be no real way to do this, since the object is based on attributes and isn't behaving like MTEXT box
What you could do is:
Create your offpage connector, connect to DWG as required.
Place an offpage connector in open area, explode it. Now the fields/attributes become editable. Overlap this text over the existing, connected one and you may perform your MTEXT edits and stack the super/subscripts.
Another method would be to create two properties assigned to the Off Page Connector class, under P&ID Class settings, Non Engineering. And call them "Subscript" and "Superscript", string.
Then edit the block for your Off Page Connector, click on the #(. ) define attributes. Place one somewhere, browse to your newly created field.
Make the text size small on this and place it in a spot that would be relevant. (I understand this is a very impractical solution to your issue where it would need to be placed between other characters). Alternatively just type #(TargetObject.Subscript)
