AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Stub-in orientation in ISO
3 REPLIES 3
ybogdanov
1056 Views, 3 Replies
 another comment. The program insert with incorrect orientation all stub-in connecions. It's happen when the stub-in it's not form part of the iso:
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
3 REPLIES 3
batone79
in reply to: ybogdanov
Did you resolve it?!....
I have one day and a Half trying to find a answer at the moment, my solution is when generate ISO.dwg, rotate each one acad block "SplitMark" to right direction, from properties.
If you have a better solution, please can you share it.?!.
thanks.
this is my messege with same problem
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Isometrics-Stub-In-split-Mark-acad-Block/td-p/3749842...
batone79
Hi Yuri again,
Speaking about this problem, I replay you that my solution was rotate AcadBlock "SplitMark" from properties.
But this solution create a wrong coordinates, so this solution is not good.
Also I change weld node (Only Weld node) to each different pipe some times in manifold and some times in branch pipe, but it is still  not work.
Sorry, any Idea?
Thanks.
ybogdanov
I don't find any solution in this moment.
Yury Bogdanov
Barcelona (Spain)
”Boost
