another comment. The program insert with incorrect orientation all stub-in connecions. It's happen when the stub-in it's not form part of the iso:
Did you resolve it?!....
I have one day and a Half trying to find a answer at the moment, my solution is when generate ISO.dwg, rotate each one acad block "SplitMark" to right direction, from properties.
If you have a better solution, please can you share it.?!.
thanks.
this is my messege with same problem
Hi Yuri again,
Speaking about this problem, I replay you that my solution was rotate AcadBlock "SplitMark" from properties.
But this solution create a wrong coordinates, so this solution is not good.
Also I change weld node (Only Weld node) to each different pipe some times in manifold and some times in branch pipe, but it is still not work.
Sorry, any Idea?
Thanks.
