Welds and stubins that are annotated and dimensioned in a normal isometric drawing do not appear in a spool drawing of same pipeline.
As a test I created a new theme from an existing isometric drawing theme and then changed it to a spool drawing theme.
Comparing the two isoconfig.xml files showed that only three lines were different.
1. In line <FileNameFormat UseSpoolNameAsFileName="false"> false is changed to true
2. In line <Auto SplitSymbol="SplitMark" SpoolSplit="false" IdentifySpools="true" SplitOnCongestion="true" CongestionLevel="2" /> Spoolsplit is changed from false to true.
3. In line <Table AllowOverflow="false"> false is changed to true.
Spool drawings are supposed to show the symbols for tap welds at stubbed-in pipes together with appropriate annotations and dimensions.
Can anybody explain why is this not happening?
