AutoCAD Plant 3D General
Active Contributor
Message 1 of 2 (229 Views)
Spec sync problem cat->spec->model->report
229 Views, 1 Replies
08-13-2012 01:16 AM
I try to exlain what my problem is as clear as possible.
I made a spec in a normal way. I use this spec in my piping file. No problems so far.
Next I modify the description of some parts in the catalog. I updated my spec an the parts in the model. Still no problems.
When I make a 3D parts report with the report creator I see the old description. Problem!
When i look in the datamanger in my piping file I see only the correct decriptions. Also when I export my datamanager file and import it back in.
When I check the properties of some parts in the piping file I see the new description.
How is this possible?
Product Support
Message 2 of 2 (176 Views)
Re: Spec sync problem cat->spec->model->report
09-13-2012 09:59 AM in reply to: snijdam
Try clearing out the local data cache by running the PnPLocalDataCachePurger.exe from the install folder of the product.
Dan
Dan Scales
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
