AutoCAD Plant 3D Forum
Spec Update
7 REPLIES 7
Message 1 of 8
thebearjed
583 Views, 7 Replies
Spec Update
why do we keep getting the spec update message when there have been no changes to the specs? i now it runs every few hours based upon user settings but if there has been no modifications to the spec why would it prompt me to apply changes?
7 REPLIES 7
Message 2 of 8
JohnHolder
in reply to: thebearjed
I am having the same issue.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Message 3 of 8
thebearjed
in reply to: JohnHolder
<cough> <cough>
Message 4 of 8
Have you checked your PLANTSPECNOTIFYTIME?
Set the time interval that spec files are checked for updates.
0 - Checks for spec file updates only when the drawing loads
1-4 Set the time interval (in hours) that spec files are checked for updates. The first check is made when the drawing loads.
You can also toggle it from ON/OFF with the PLANTSPECNOTIFY
Let me know if this helps.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
Message 5 of 8
JohnHolder
I think the main issue, is that the spec has not changed, but the notice pop's up
Master Yoda.
Message 6 of 8
thebearjed
turning it off or changing the time between checks does not fix the problem.
if a check is run and there are no changes to the spec  then you should not get a message to "apply changes."
Message 7 of 8
dave.wolfe
I think it is also checking to see if there are items in the model that need to be updated to match the latest spec descriptions.  I think when you insert items, you get the latest data from the spec.  So the spec update is more for checking descriptions compared to the model not necessarily whether there are new items in the spec.
One thing I've been recommending is that people do not modify the long description fields manually, as the spec update will overwrite those fields.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 8 of 8
EricNyh
in reply to: dave.wolfe
Old thread..
Has this been answered yet?  I haven't made any changes to my specs for weeks, yet I keep getting pop-ups that indicate my specs have changed.  Is this broken or am I confused of what is actually going on with this check/update feature.
My specs have been migrated from 2013 and the long description fields have been updated, as the default ones did not suit me.
I have gone into the Project Setup and disabled the spec update settings for the short and long descriptions, just to make sure things don't get changed.
”Boost
