What are the Spec Notes for? I see where you can "Add Notes to Group" in the spec editor but what does it do? Is it just a note to someone working in the spec or does it show up in the model somewhere?
Solved by jtegtmeyer. Go to Solution.
TR, We use them to show the notes in the SPEC VIEWER and a scan/printed version of the specs. This way if the customer spec layout is confusing you can hand a copy of these to your team.
