AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Spec Editor Parametric Component Addition
3 REPLIES 3
nihanisbil
860 Views, 3 Replies
I am trying to create my own catalog on the spec editor.
When the "Parametric Graphics" of the Plant 3D Software is not enough for me; how can i create new 3D parametric component by myself and add it to my catalog?
For example, i'd like to use a valve shape that is not similar with the Plant 3D default "Parametric Graphics". I don't want to create all of the shapes for each size. (I mean i don't want to "Add Shape" for each size)
I want to identify each parametric value (for exapmle length) and then export the information to Catalog Builder Excel and change the parametric values for each size. Is that possible?
Best;
3 REPLIES 3
jabowabo
in reply to: nihanisbil
nihanisbil
in reply to: jabowabo
Hi jabowabo,
Thank you for the quick reply. But I think scripting is a little bit advanced for me.
I can create 2D parametric blocks on the basic AutoCAD. I'm wondering, whether I can do this for 3D parts or not.
I'd like to download a custom 3D block, (1 block) and identify some parametric values for it; then add it as custom Plant 3D parametric graphic and use it for several diameters.
Best;
jabowabo
Unfortunately, I think scripting is the only option to create your own parametric shapes.
”Boost
