AutoCAD Plant 3D General
Valued Contributor
vannmannen
Message 1 of 5 (308 Views)
Spade & Spacer
308 Views, 4 Replies
11-27-2012 09:56 PM
When placing a SPADE between 2 flanges, I need the BOM to show the SPADE aswell.
Is there a set-up in the spec editor for this?
Product Support
Message 2 of 5 (243 Views)
Re: Spade & Spacer
12-06-2012 09:20 AM in reply to: vannmannen
If the SPADE has been inserted in the model it should be listed in the BOM using the Long Description (Family) name. It does also require an Iso Symbol Type and Iso Symbol SKEY.
If you look at the Paddle Blind in the ASME Pipes and Fitting catalog you will see how it is setup for that.
Dan
Dan Scales
PatrickByrne
Message 3 of 5 (232 Views)
Re: Spade & Spacer
12-06-2012 04:28 PM in reply to: Dan.Scales
I believe he is looking for two objects in the BOM.
Unlike a Paddle Blind the Spade also comes with a spacer therefore he needs to have two objects listed in the BOM, the spade itself and the spacer. It is used on larger diameter pipes, normally the spacer would be assembled in the pipe line with the spade been kept in storage until required.
Previously in CadWorx I created a very thin Gasket object and renamed it as the paddle blind, this way it does not show up on the Isometric but still appears in the BOM.
How would we show this in Plant 3D
Valued Contributor
vannmannen
Message 4 of 5 (228 Views)
Re: Spade & Spacer
12-06-2012 05:09 PM in reply to: vannmannen
Correct Patrick: when you place the SPACER I need the SPADE to come up in the MTO automatically as you always purchase these as a set.
The quick-fix solution of placing a thin gasket will of course work but that is not the way it should be done.
The program should place 2 components where 1 of them has thickness of 0mm. This would give you 2 items in the BOM but no deviation in the face-to-face dimensions.
Product Support
Message 5 of 5 (181 Views)
Re: Spade & Spacer
12-13-2012 03:08 AM in reply to: vannmannen
For now I think you will need to go with the workaround.
I will log a feature enhancement wish with our developers for the functionality you need.
Dan
Dan Scales
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
