Hi all
i have some question about pipe support in 2012,could you pls help to check it,thank in advance:
1.how to make tag of pipe support not unique?
2.how to make tag of pipe support display on ISO drawing?
thank you
I think I have a workaround for this issue.
As long as you have tagged your pipe supports in the model, you can modify the IsoConfig.xml to display that tag number that has been entered.
Open the IsoConfig.xml file for the Iso style you are using. For example:
<project name>\Isometric\Check_ANSI-C\IsoConfig.xml
(You can use Windows Notepad or XML Notepad to make the changes)
Search for "SUPPORTSTANDARD"
It should find this line here:
<!-- Pipe support standard
<ComponentScheme Name="SupportStandard" AnnotationStyle="Standard" Format="{0}" Grouping="true" Alignment="FlatHorizontal" LeaderStyle="Always" Filter="Support" Fields="SUPPORTSTANDARD"/>
Change the value for Fields from "SUPPORTSTANDARD" to "TAG" as shown below:
<ComponentScheme Name="SupportStandard" AnnotationStyle="Standard" Format="{0}" Grouping="true" Alignment="FlatHorizontal" LeaderStyle="Always" Filter="Support" Fields="TAG"/>
The support tag will be shown by the BoM annotation:
