AutoCAD Plant 3D General DIscussion
Distinguished Contributor
EricNyh
Message 1 of 7 (1,203 Views)
Small bore pipe support (dummy leg/stanchion)
1203 Views, 6 Replies
01-21-2013 01:17 PM
I'm a Plant 3D newbie.  We use the attached support quite a bit.  I'm not sure how to build this within P3D.  One thing I have tried is to create an AutoCAD entity and convert it to a pipe support.  This will attach it to the SW tee, but I'll still have the "drip" symbol.
Any suggestions would be appreciated.
Product Support
quentin.contreras
Message 2 of 7 (1,142 Views)
Re: Small bore pipe support (dummy leg/stanchion)
01-24-2013 02:32 PM in reply to: EricNyh
Can you provide a screen shot of what you have converted to pipe support? I would like to see where the "drip", disconnect marker, is being placed.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
EricNyh
Message 3 of 7 (1,121 Views)
01-25-2013 08:48 AM in reply to: quentin.contreras
Attached is a JPG.
My process for creating the support was to make an AutoCAD object, move it to the location, then use the PLANTPIPESUPPORTCONVERT command and chose the socket of the tee as the insertion point.
Thank you.
EricNyh
Message 4 of 7 (1,056 Views)
02-06-2013 05:46 PM in reply to: quentin.contreras
Quentin,
I didn't realize that you were the same person I had talked with on the phone, the other day, about my other issue with my line numbers not working.  :smileyhappy:
You haven't happened to make any progress on this issue have you?
Eric
Product Support
quentin.contreras
Message 5 of 7 (1,037 Views)
02-07-2013 04:54 PM in reply to: EricNyh
I am sorry I did not get back to you before now. The easiest thing to do would be, for the threaded 3 way tee is just to place a plug. Then you could model your our support and convert support. This would also apply if you are using a SW tee.
However, then you would have a plug that would show up in you BOM. The other option would be is the generate a custom tee with one end plugged.
You can refer to this web link on creating Custom Companents.
http://www.pdoteam.com/2011/10/custom-components-in-autocad-plant-3d/
Let me know if this helps.
Quentin Contreras
Product Support
quentin.contreras
Message 6 of 7 (1,011 Views)
02-11-2013 05:07 PM in reply to: quentin.contreras
Just checking to see if this helped or were you able to find another solution.
Quentin Contreras
EricNyh
Message 7 of 7 (994 Views)
02-13-2013 08:29 PM in reply to: quentin.contreras
Hello Quentin.  I finally got around to trying one of your suggestions.  I took a round plug and changed it's size to mimic a 4" long piece of round bar.  This seems to fix the "drip" connection.  As soon as I attach my pipe support to the plug, the "drip" reappears, but is only visable if you select the support.
For the iso's, I can probably just create a new iso symbol for the round bar so that it includes the "duck" and then just fake the duck in the model.  If that makes sense.
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
