AutoCAD Plant 3D General
*Patrick
Message 1 of 2 (190 Views)
Sloping pipework
190 Views, 1 Replies
03-31-2010 04:19 AM
How does Plant 3D handle sloping pipework. Angles can vary from a few
degrees to 90 degrees.
Employee
Message 2 of 2 (190 Views)
Re: Sloping pipework
03-31-2010 06:20 AM in reply to: *Patrick
You can slope pipe 2 ways prior to routing you can activate the slope panel on the 3D Piping Home Ribbon this will slope horizontal pipe per the specified ratio.
The second can also slope pipe after it has been already routed by using the command PLANTPIPESLOPE. This will allow you to slope a selected route with multiple segments and enter a common slope. Choose the starting pipe segment then the last pipe segment even if its across multiple piping fittings and other pipe segments.
Mike G (Autodesk)
Michael Gulnac
Technical Specialist
Organization
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
