I am having trouble setting up a basic fiberglass spec, using the bondstrand catalog that I downloaded from here.
Are there are sample specs available? or does anyone have a spec that they are willing to give to me? Im working on an industrial waste line.
Could you please give us more information on the issue you are having?
The spec is something that the process engineer or customer will tell you.
Tom,
He had mentioned that he has some issues setting up Fiberglass spec, I recently helped a customer to set up Fiberglass spec (Bondstrand) so I am trying to get an idea on what type of issue he is having.
I understand, but setting up a spec needs some more information than just the catalog. For example, whats the size range? Are there any extra rated fittings etc in it? Also the branch table needs to be defined, but its not like there is a 'standard' piping spec, they vary from project to project, and from client to client.
I'm not sure on what the OP is asking, is the catalog the issue, or making the spec?
Thats exactly what I am trying to understand from him.
