AutoCAD Plant 3D General
Valued Mentor
JohnHolder
Message 1 of 7 (572 Views)
Service Acquisition on pipe run components
572 Views, 6 Replies
10-02-2012 03:24 PM
Is there a way to remove "acquisition" on selecting a service? I do not want to have to override the lines all the time.  I went into the project properties and went to <Plant 3D DWG Settings> down to <Pipe Run Component> and turned off <Acquisition> in the <Default Value> - then it just removed the Service field on the pipe runs.  So then I removed the Acquisition rule, and it still still does not fix the problem..
I overrode the line colours to match what I want them to be and tied them to simple service types which I use.
RS for recirc supply water - blue colour
RR for recirc return water - red colour
etc etc
For my industry, this works great.. I don't care about having different colours for nominal sizes.
I just want to easily change the service. Is there anyway to set this up? or a better way perhaps?
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
dave.wolfe
Message 2 of 7 (567 Views)
Re: Service Acquisition on pipe run components
10-02-2012 05:46 PM in reply to: JohnHolder
Easiest way I found to change the service is through the Data manager.  In 2013, there is an drop down at the bottom right to switch between object type and order by Area. When you choose Area, there will be a lines node, which represents the Pipe Line Groups.  With that level selected, you can select the service for the entire pipeline group.
I assume you are using the layer automation from project setup?
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Valued Mentor
JohnHolder
Message 3 of 7 (553 Views)
10-03-2012 08:58 AM in reply to: dave.wolfe
Yeah I found it, opened the line number and <service> is greyed out and locked.
so I exported the data, unlocked the worksheet then changed the service
relocked the worksheet and saved it.
Imported the modified worksheet and nothing happened.
I must be doing something wrong.
Master Yoda.
dave.wolfe
Message 4 of 7 (551 Views)
10-03-2012 09:00 AM in reply to: JohnHolder
Can you post a screenshot of the view of your data manager?
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Valued Mentor
JohnHolder
Message 5 of 7 (548 Views)
10-03-2012 09:04 AM in reply to: dave.wolfe
Here is the screen shot.
I still have some untagged lines that I need to fix.
edit
1001 - RS
200# - RR
8001 - Wa
Master Yoda.
Product Support
Dan.Scales
Message 6 of 7 (503 Views)
10-05-2012 06:45 AM in reply to: JohnHolder
HI,
If you select "Pipe Lines" from the list you can Export the active node, make the changes to the Service and then import those changes.
Note the Service field is not grayed out in this view:
It is also possible to make changes directly in the Data Manager.
Dan
Dan Scales
Valued Mentor
JohnHolder
Message 7 of 7 (482 Views)
10-05-2012 12:31 PM in reply to: Dan.Scales
I see!
I went one lvl too deep into the pipe lines.
Thanks.
Master Yoda.
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
