AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
SQL and Report Creator
14 REPLIES 14
Message 1 of 15
933 Views, 14 Replies
I have a problem with Report Creation only for projects with SQL Expess.  With other projects everything is good.
14 REPLIES 14
Message 2 of 15
r.vanderend
We have the same error with SQL.
There is no dialog to log in.
Message 3 of 15
Same issue here with the ProcessPower.dcf error.
Message 4 of 15
MangeshKalbhor
The Report Create will work with Windows Authentication for SQL Express. With SQL Authentication there is some issue opening project data and we are currently looking at it. Expect something soon on this.
Mangesh Kalbhor
Autodesk Plant Solutions
Autodesk, Inc.
Message 5 of 15
PeterQuinn
Thanks for the heads up. We've confirmed that this is an issue and are working on it. As usual, I can't give any details on when it will be addressed.
Peter Quinn
Senior Product Manager
Autodesk, Inc.
Message 6 of 15
r.vanderend
Thanks for recognizing the problem, I hope on a hotfix soon.
Message 7 of 15
ybogdanov
Report Creator ne rabotaet v proektax kotorie podkreplenni s SQL serverom, tak kak SQL server imeet svoi sobstvennie vozmojnosti dlya formirovaniya dokladov, na primer Report Builder.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Message 8 of 15
in reply to: ybogdanov
Spasibo bolwoe, ybogdanov
Message 9 of 15
If anybody has the same problem and wants to use Report Creater with Project with SQL Express, there is one trick.
In the project folder there is 4 files
 iso.dcf
otho.dcf
Piping.dcf
ProcessPrower.dcf
Then in every file after the Integrated Seguruty paste the following
<Name>Integrated Security</Name>
<Value xsi:type="xsd:boolean">false</Value>
</Parameter>
<Parameter>
<Name>user id</Name>
<Value xsi:type="xsd:string">sa</Value>
</Parameter>
<Parameter>
<Name>Password</Name>
<Value xsi:type="xsd:string">as</Value>
</Parameter>
<Parameter>
sa - is the id name
and as is the password
After that everything works good.
May be there is a way how to avoid this operation?
Thank you very much
Message 10 of 15
r.vanderend
How to edit this files?
I see only strange symbols..
Message 11 of 15
in reply to: r.vanderend
I opened with notepad
Message 12 of 15
r.vanderend
It works, thank you!
Message 13 of 15
Thanks for this solution.
It's a solution which Autodesk unfortunately didn't provide. 😞 :(Smiley Mad
Best regards,
Gerald
Message 14 of 15
ybogdanov
The solution it is in the Service Pack 1 for Plant3D 2012:
"Report Creator
Corrected a problem that prevented Report Creator from opening projects that require SQL authentication"
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18430575&linkID=14116968
Yury Bogdanov
Barcelona (Spain)
Message 15 of 15
Ohhh:)
Thank you very much. It's very very good!
”Boost
