SDR 35 - PVC Gravity Sewer pipe and fittings
Does anyone know which content pack if any would contain this? I am not sure where to look.
It would be nice to have somewhere to start instead of building it entirely from scratch.
John.
Solved by quentin.contreras. Go to Solution.
Besides looking through the contents packs provided in the Autodesk Exchange for AutoCAD Plant 3D would be the only place I would suggest to find the content. I do not see it and it seems you will have to build the content yourself.
I would also suggest you send a request to the Plant Content team to have them look at providing this content and any other content you might be thinking about using in the future.
Quentin Contreras
Technical Support Specialist
yeah, I will most likely have to create the spec from scratch. I've tried requesting Sch 40 and PVCu no real luck with that either. Unfortunatly only partial catalogs are avaliable. Unfortunatly I use pipe specs that not many others use.
