AutoCAD Plant 3D Forum
SDR 35 - PVC Gravity Sewer pipe and fittings
2 REPLIES 2
JohnHolder
1363 Views, 2 Replies
Does anyone know which content pack if any would contain this?  I am not sure where to look.
It would be nice to have somewhere to start instead of building it entirely from scratch.
John.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
2 REPLIES 2
Besides looking through the contents packs provided in the Autodesk Exchange for AutoCAD Plant 3D would be the only place I would suggest to find the content. I do not see it and it seems you will have to build the content yourself.
I would also suggest you send a request to the Plant Content team to have them look at providing this content and any other content you might be thinking about using in the future.
plant.content@autodesk.com
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
yeah,  I will most likely have to create the spec from scratch. I've tried requesting Sch 40 and PVCu no real luck with that either.  Unfortunatly only partial catalogs are avaliable.  Unfortunatly I use pipe specs that not many others use.
Master Yoda.
”Boost
