AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Resistoflex Lined Pipe Catalog
6 REPLIES 6
1594 Views, 6 Replies
I recently downloaded the Resistoflex Lined Pipe Catalog from Autodesk Exchange.
I am having issues with the isometric representation of the lined fittings, ie. the lined pipe spools show up as placeholders and fittings show up as welded fittings. Lined piping isometrics are required to show dimensions at each flange for exact dimensions of each spool and fitting.
Has anyone else modified the downloaded catalog to show the correct representation of lined fittings?
If so, how is it done and how difficult is it to achieve this?
Thanks in advance.
6 REPLIES 6
It's necessary revise SKEY and TYPE in the properties of the elements. Open Catalog Editor, and change it.
TRdesigner82
Where did you find an Autodesk supplied Resistoflex Catalog? I just looked on the site and I'm not seeing where there is a content pack for that...
Hi There
The Resistoflex Catalog was removed from the site because of the errors in the Iso's produced.
Once the errors are fixed hopefully it will be upload it again 🙂
Kind Regards,
Tarryn
Bob_Lipchik
Does anyone have the Resistoflex catalog that was removed that they would want to share with me?  I have just a small amount of lined piping on a project and don't want to have to go to the trouble of creating all of the fittings.
I have Resistoflex's catalogue.
If you leave your e-mail me I you send it.
Best regards, Jose
p..d jose.gimenez@fluor.com
Bob_Lipchik
Resistoflex catalog received.  Thank you Jose and TRdesigner82!!
Bob
”Boost
