AutoCAD Plant 3D Forum
Resistoflex Flange Navisworks Issue
1 REPLY 1
326 Views, 1 Reply
Has anyone had problems when viewing Lined Piping in Navisworks?  When I view the piping in navisworks the pipe segment flanges are white not the color line layer or service it is on.
If I explode the pipe and match the properties of the line to the flanges that are white it works fine.
1 REPLY 1
AndyDavisCadline
You're quite right.  I suspect it's the way that the flanges are added to the pipe and incorporated into the composite Plant item.  If you notice, when you select one of the flanges in Navis, the other is selected too.  The AutoCAD colour index  is always 7, white.
You can always Presenter to 'paint' the pipe. 🙂
Andy
Andy Davis
Industry Specialist
Cadline Ltd.
”Boost
