Has anyone else used the Resistless catalog that used to be supplied by Autodesk? I've noticed that the flange thicknesses that they're using don't include any lining thickness. I don't know how that works with the bolting but it seems to be a reoccurring theme with things supplied out of the box or by the Autodesk team. Components don't seem to be what you'd expect them to be. Especially something being supplied by Autodesk, I'd expect it to be right. I'm pretty disappointed with the type of thing that I'm finding...
Training in spec editor helps!
Autodesk is not responsible for everything that is available in the catalogs. The user should have his pipe specs themselves produce from the catalogs and possibly the catalogs must be precisely adjusted and changed.
regards
Hartmut
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
