Using the Report creator I can't seem to be able to get any reducing parts (eg. reducers, Olets, reducing tees) to show the branch size in the ND field. It currently shows the header size only and groups all parts together. eg if i have two weldolets with a header of DN100 but one with a branch of DN50 and the other DN40 then they will be grouped together showing the quantity as 2 DN100 weldolets.
I don't really want to go through all the reducing parts in the spec creator to add the sizes back to the size description.
Can anyone help me please?
To show what I mean i have attached a generated report.
Scott
The original issue is getting to show the size (ie 4"x1") in a field by itself in reports, not having items with similar sites groups in the same row.
I attached a dwg called B.O.M. Test and the pdf that I got from the report generator. I managed to separate piping elements by material and spec.
The reducer sizes come out as requested. All parts come out with their specific designation or description.
In my spec I filled in the 'Short Description' field and so far, it works !
cheers,
Marc
I just noticed I attached the wrong Bill Of Material.
Hereby the correct one.
Cheers,
Marc
Exactly, some people want the size in a separate column, which is not what you show. Our plugin will populate a separate column with the size displayed in the properties palette.
Dave,
Thanks for clearing that up, it is quite simple to edit the descripion of the component to show the size in the bom, but then again thats still work needed to put that in and its not the proper way to list item size when creating a professional report.
PLEASE keep us posted as to when this plugin will be released, will save me from getting grey hair at such a young age.
Kind Regards,
Geoff
How it's possible to get Quantity to show also number of bolts?
Now it only show the quantity of bolt set's but I need to it show number of bolt.
Of course I can make new coulum which show how many bolt in set but it would be better in Quantity
Here ya go... http://www.pdoteam.com/2012/10/enhanced-fields-for-autocad-plant-design/ We're releasing the plugin today. Feel free to leave comments on the blog, or contact us via the website.
With regard to the bolt totals, that should probably be addressed in a new thread.
Hi Dave,
The Video doesnt show anything about the reducer sizes shown properly in the report creator!???
can you know show us that it works before we even purchase the Plugin?
Geoff
Yes, I have to make the rest of the videos still.
Please post the link that allows us to download the plugin....i cant seem to find it on the web site???
The link to the plugin in our store is here: http://www.pdoteam.com/store/pdo-extended-fields/
FYI, somehow the add to cart button had been disabled, but it should be fixed now.
