Hello
in a report I've inserted a picture box. I want to change the URL (path) variable depending on the project with the content of a field in the project properties.
Is that possible or are there some other ideas?
Guido
Solved by GSC_HAYA. Go to Solution.
Just to confirm the question, is it that you want a different image to be used in the report depending on the project that you run the report on?
Dan
yes, this is exactly what I want.
Hi Guido,
I have logged a feature enhancement request with our developers for this functionality.
In the meantime you will need to use a different report for each project that contains the required image.
Dan
The report creator has a very power scripting capability. You can do this with a some scripting. A good place to start is here: http://www.pdoteam.com/2012/06/introduction-to-scripts-with-the-plant-3d-report-creator/
here is the right answer.
I've contacted the support from DevExpress, they developed the reportcreator....
Assuming that the report data source collection includes a data field with the required picture URL value, use the Properties window -> Data Bindings -> Image URL option to link your picture box control to the corresponding data field (see http://screencast.com/t/prRMXWExxtM). It is possible to use this approach to link your picture box control to a report parameter (see the XtraReport.Parameters collection)
Many, many Thanks to the support.
Guido
