Hi
I know this issue has been resolved here before, but non of the solutions has been succesfull to me. I use "3D Parts" as report configuration, but this configuration does not separate/sort between different material codes. E.g. if my model consists of pipes of nominal size DN400 consiting of two different material codes, the report only shows one single line of pipes in dimension DN400. I would like the report to consist of two lines, line number one summarizing the cut lengths of DN400 pipes consiting of material code nr. 1 and line number two summarizing the cut lengts of DN400 pipe consiting of material code nr. 2.
I have tried both "Edit query" and "Edit report layout" without any luck. Please help!
Best regards...
Solved by jabowabo. Go to Solution.
Could jabowabo help you? Alternatively you can direct add new group headers in the report formula. For example Group header ND and group header Material Code or one group header with both types and group it in a collection ( see attached snapshot).
Regards
