AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Report Creator Errors
5 REPLIES 5
getrekdent
501 Views, 5 Replies
When I run Report Creator and select the dropdown to direct it to my drawing file it isnt there.. When I type in the actual string to the files location I get an error message? Any Suggestions? All I am trying to do is get a BOM off the drawing
BoXx ApeXx S3 Workstation - 64 GB Ram
i7 Overclocked to 5.1GHz - Nvidia Quadro P6000
5 REPLIES 5
patpat79
in reply to: getrekdent
Why is the project blank?
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
getrekdent
in reply to: patpat79
That's what it does when I try and open it in the Report Creator.. It's
Weird
jabowabo
You need to open the Project.xml file in the root of the project folder.  You can select your drawing after that.
getrekdent
in reply to: jabowabo
You have solved my problem, Thank you very much! Can't believe I didn't
notice that!
Cheers!
patpat79
That's why I am asking why your project is blank. It's good to have your problem solved.
Best Regards,
Pat Andres
GHD Manila
”Boost
