When I run Report Creator and select the dropdown to direct it to my drawing file it isnt there.. When I type in the actual string to the files location I get an error message? Any Suggestions? All I am trying to do is get a BOM off the drawing
Solved by jabowabo. Go to Solution.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
You need to open the Project.xml file in the root of the project folder. You can select your drawing after that.
Best Regards,
Pat Andres
GHD Manila
