Hi, Plant adepts!
What is the best way to replace equipment in Plant 3D Pipe Model to another one, except to delete this eqiupment and place new one?
Hello Roman,
in AutoCAD P&ID you have the possibility to substitute the equipments by using the dynamic grip which will appear when you have selected the equipment. This is currently not possible in AutoCAD Plant 3D. You have only the possibility to modify the selected equipment, e.g. the cylinder, the torispheric head, ... If you want to have the same possibility to substitute different equipments in future releases, please, log here an enhancement request directly to our development department.
Regards
Bernd
Hello, Bernd!
Thank you! I suspected that it is impossible in P3D. Now you can to close my case.
