Hi Autodesk Support
I tried to Renumbering the Nozzle of one vessel I did, but when I put N5 for Example he give me the window screen it’s already exist and if I go inside the nozzle I can’t found the N5 From where he give me this massage. For more clarification refer the print screen in the attachment file
Ahmed Helal
Solved by Dan.Scales. Go to Solution.
Try closing the project and then Plant 3D and then clearing the User Data Cache. To do that you need to double click the PnPLocalDataCachePurger.exe that is located in the install directory of the product.
Dan
Hi Dani,
This solution Not working please Refer to Screenshot in the attached file
Ahmed Helal
Ctrl + click on the nozzle, click the pencil grip.
At the top will be the tag, click the arrow button to expand a section where you can renumber the nozzle. Remember that if a number is already used, you'll have to change number in a particular sequence. For example, if I have nozzles N1 - N7 and I need to add a new nozzle for, I have to start with N7 and renumber it to N8, and continue until N4 is available.
In some situations where tags have existed, you may need to run COMPRESSPROJECT in order to clear out the old tags.
Solved by exporting the nozzle list to excel and importing the corrected numbers.
Dan
