AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Removing mulitiple catalog part sizes from a spec at the same time?
1 REPLY 1
TRdesigner82
357 Views, 1 Reply
I'm using Plant 3D 2013. Is there a good way to remove mulitiple catalog part sizes from a spec all at the same time?  I know I can check the Remove From Spec box on every size I what to remove but there seems like there should be a quicker way than that...
1 REPLY 1
in reply to: TRdesigner82
During adding elemento to the spec use size filters to add only sizes which you want.
 For more fast select you can use Space boton and down boton of keyboard.
”Boost
